EAGO AM199HO 5 FT. ROUNDED CLEAR MODERN DOUBLE SEAT CORNER WHIRLPOOL BATH TUB W FIXTURES INLINE HEATER AND OZONE DISINFECTOR - WHITE
High Gloss Acrylic: Our fiberglass-reinforced MaxLoad high gloss acrylic is stronger and more resilient than the material used by our competitors. The acrylic is scratch resistant and extra-smooth making it difficult for dirt and bacteria to attach and easy to clean. EAGO acrylic bathtubs are reinforced by fiberglass and stainless steel. 2 person capacity
Double the Pleasure
This model features both Air jets and Hydro jets by having an air pump and a water pump. The 8 jets on the bottom blow air and all the other jets are hydro which means they release water for massage. Each system can be controlled independently. Includes hand held Chromed Shower Head and an Auto-protection function: pump will not start if water level is inadequate Water Hydromassage Jets
Includes 10 Jets that provide relaxing and rejuvenating hydro massage therapy. 6 for the back 2 for feet and 2 from the side. Chromotherapy: 8 LED lighting modes to choose from create a serine atmosphere. Includes Inline Heater. The Inline Heater will maintain the water temperature dispersed into the tub when filling it up. As the water circulates within the tub it is heated to ensure that you can enjoy the perfect temperature for as long as you wish. The Electrical Requirements: 23Amps 2500 Watts 110V 60HZ Water Capacity: 100 gallons Tempered glass panel: 1/4 thick (6mm). Ozone Disinfector Function: The high oxidation potential of ozone is utilized to its greatest advantage with ozone disinfection equipment. Ozone is a safe and natural chemical derived from the oxygen we breathe. An ozone generator is attached to the air supply of the whirlpool jets. The ozone disinfection system completely breaks down pollutants through destruction of pathogens in the water particularly; killing bacteria inactivating viruses and removing parasites. Ozone is an effective sanitizer that is 200 times stronger than household bleach and will keep your bath water clean
Price: 10725.00
