EAGO ALFI TRADE AM151-L LEFT DRAIN 6 FT. MODERN WHIRLPOOL BATH TUB WITH COLORED LIGHT UP GLASS PANEL- WHITE
2 person capacity.
2 HP Ultra Quiet Water Pump.
Electrical Requirments: 110-120 Volt 60Hz 30 Amp / 1500 Watt.
Auto-protection function: pump will not start if water level is inadequate.
Wasteway with trap prevents odors from the drain system.
Ozone disinfection function.
Includes a thermostatic tub filler with hand held shower head.
Tempered glass panel 1/4 thick (6mm).
LED Lighting Front Panel: Amaze yourself and your next guest with a unique LED lighting system on the front glass panel of your new whirlpool tub.
Chromotherapy: Set different lighting schemes to match your mood with 7 different LED color schemes to choose from.
Touch Screen Control Panel: Stylish control panel with backlit buttons. A touch-sensitive user friendly interface allows you to easily operate the bathtubs whirlpool jets inline heater digital sound system and chromotherapy light.
High Gloss Acrylic: Our fiberglass-reinforced MaxLoad high gloss acrylic is stronger and more resilient than the material used by our competitors. The acrylic is scratch resistant and extra-smooth making it difficult for dirt and bacteria to attach and easy to clean. EAGO acrylic bathtubs are reinforced by fiberglass and stainless steel.
Digital Stereo Sound: Select your favorite radio station using the touch screen panel then just sit back and relax.
Water Hydromassage Jets:Includes 21 Jets in total with 5 back hydro-massage jets 8 bottom hydro-massage 2 Feet 6 Sides. To provide relaxing and rejuvinating hydromassage therapy.
Water Fall: Enjoy the soothing sound and look of the water fall which fill the tub and continues to flow once the tub is full to circulate the water.
Color: White.
Installation Type: Free Standing.
Water Capacity: 99 Gallons.
Dimensions:: 70 7/8 x 35 1/2 x 25 5/8.
Price: 10595.00
